2005 Suburban rollover valve???
Old Nov 6, 2023 | 5:23 PM
FLseminarian's Avatar
Question 2005 Suburban rollover valve???
I'm trying to troubleshoot the recurrent problem of slow fill at the gas pump. Last time I did this replacing the canister and vent solenoid didn't help. I've been living with it for over a decade.
I'm trying to think ahead. I'm trying to look for a rollover valve, in case that's the issue. Can't even find a part number. Is that a separate part on a 2005 C1500 5.3 Flex, or was that an integral (and non-replaceable) part of the tank?
Old Nov 6, 2023 | 6:21 PM
it's usually a plugged filler neck or tank vent. try carefully blasting some compressed air through them.
Old Nov 6, 2023 | 9:21 PM
Thanks. Tried that already. Disconnected that at the fitting on the Evap tubing 'snake' that sits on top of the tank. Blew compressed air up through the filler neck vent tube. Didn't help.
Hoping to avoid dropping the tank, but realize I may need to finally do that.
Hydrostream1
Aug 19, 2023 1:02 PM
PolarSuns
May 1, 2020 12:42 AM
Brandy Roberts
Oct 15, 2017 9:26 AM
rz0y66
May 7, 2015 11:46 AM
BillL
Mar 15, 2011 8:33 PM
