2005 Suburban Z71 1500
Old Jan 28, 2017 | 2:12 PM
Tim Waybrant's Avatar
Default 2005 Suburban Z71 1500
It will not blow hot air at idol but will as soon as you give it some gas,then blows cold air when stopped
Old Jan 28, 2017 | 3:31 PM
kevinkpk's Avatar
Whats the temp gauge showing?
Old Jan 28, 2017 | 3:54 PM
Rednucleus's Avatar
Any recent cooling system work? When was coolant last changed? Any leaks? Wonder if you have air in the system blocking flow thru the heater core.
Old Jan 29, 2017 | 9:02 AM
WyrTwister's Avatar
Do not know if a 2005 user 100% electric controls for the heat & A/C ? Or if some of the controls were still vacuum operated ?
If vacuum operated , you may have a vacuum leak or something similar ?
I drive a 2008 Silverado company truck & pretty sure it is all electric / electronic .
Any check engine lite codes ?
God bless
Wyr
Old Jan 29, 2017 | 10:53 AM
intheburbs's Avatar
Did you check your coolant level? That's the most common cause.
Old Jan 29, 2017 | 10:58 AM
WyrTwister's Avatar
Excellent point ! :-)
God bless
Wyr
