2006 tahoe reduced power/disabled stability system...
Old Jul 22, 2013 | 7:13 PM
QUICK CHARLIE's Avatar
Default 2006 tahoe reduced power/disabled stability system...
My 2006 tahoe slowed down...message: Engine reduced power / disabled stability system...accelerator wouldn't work ...vehicle ran at 10 +/- mph...tc (traction control symbol lighted)...) ...(check engine symbol lighted) pulled off road...let sit 10 minutes or so...started up ,ran fine ...drove a few hundred yards same thing occurred...had towed in (from baltimore suburbs to arlington,va.garage)...garage found nothing wrong...no messages , no codes... Test drive +/_ a mile ran fine ...picked up car drove about 2 miles ...o.k. ...next day drove about 1 mile ,happened again...this time check tire alert system message as well as others...back in garage for repair... I've read everything i can find on internet...seems nobody gets this problem fixed ...can't rely on my tahoe for my weekly trips to baltimore (125 -130 miles round trip) no confidence that this not continuing to happen...anyone have any positive advice other than "get a new ford" ...???
Old Jul 24, 2013 | 5:43 PM
After two tries at repair, wire in harness found broken inside insulation...only charged for labor...reasonable $ 178 ...hope that was all that was needed...recommend andersons sunoco / jim domenico ...he has always been reliable and reasonable ...quick charlie 7/24/2013
Old Jul 25, 2013 | 1:02 PM
SWHouston's Avatar
Yep, I replaced the Harness on mine too, but had to go though the Grounds as well. There's been a LOT of discussion on this, and these items haven't been all that caused the message. Mine hasn't done it in quite a while now.
But I understand, I was running in the middle lane of I-10, 60-70 mph, 5pm, and all of a sudden, I'm only able to drive 10-15 mph.
NOT a good feeling.
Old Oct 4, 2014 | 9:42 AM
knjwells's Avatar
Default Which harness?
Which harness was it? I am having the same issue and I have had a few harness and connectors issue
Old Feb 7, 2020 | 7:27 PM
Bryant White's Avatar
Default reduced power
My 2006 did the same thing. Turns out I had to replace the fuel pump. Now I’m getting the Stability Sys disabled code
slatkins
Jan 20, 2020 8:41 AM
dcanada92
Jan 12, 2016 8:46 PM
linolakes55
Jul 7, 2010 9:23 PM
vivero
Jun 24, 2007 12:23 PM
vivero
Jun 23, 2007 2:38 PM
