2007 BCM location
2007 BCM location
Hi All,
So I was changing my front passenger side differential seal and then I changed my drivers side cv axle. The job was straight forward and went thru without a hitch.
Then when i put my car down from the lift, I couldn't start the car.
The windows go up and down, the wipers run, headlights run, dash lights come on, radio comes on
the batter is full, the remotes and power locks dont work, interior lights dont work,
but the engine doesn't crank, my friend ran the diagnostics and some code of lost communication with control module came up.
Needless to say i purchased an ac delco bcm from ebay based on my VIN.
Now where in the world does this little black box go?
Ive seen diagrams of 07 tahoe showing under the driver side front wall, under the center console. I have yet to take out the console since i dont know how, but have ordered a chiltons book in the mean time.
Any help both written or image would be great
2007 suburban LT 1500
5.3 LC9
5.3 LC9
location of bcm
found the BCM its located under the steering column, 3 screws and some pulling and i got it out.
of course being the genius i am, i got it out and installed the new one, but then i realized i could have just taken this thing to the dealership and given my vin and they wouldn't have charged 1 hour labor.
the car starts and runs like it should now.
BCM was bad and needed replacement
the BCM went bad, i should have seen this coming because earlier my remote start stopped working and little odd end things started happening in the car like dome lights wouldn't work based on how i set it up or chimes would go up and down
subtle changes
subtle changes
d1nonly34
December 10th, 2008 11:05 AM
