2007 chevy suburban power lift gate problem
Push any of the buttons to open the tail gate and it does not open. It makes all the noises and unlatches but does not open. When manually opened, I push the button it makes all the noises and does not close. The motor is working, but my guess is that the mag clutch is not engaging and I dont know why. I call it the mag clutch, because I dont know what it is called. It uses electricity to engage when it open or closes. any help would be appreciated.
Originally Posted by steve8691
(Post 227462)
I would like to look into this concern for you. Will you please send me your first and last name, address, VIN and current miles on the vehicle. Thank you, Tina Chevrolet Customer Service |
steve darden, xxxx, utopia, tx xxxxxx,xxxxxg280838, 90,000 miles
I am having an identical issue. What is it?
latch assy?
Local dealers says its the latch assy inside the door. supposedly not sending signal to the powerlift gate assy to open or close. They want $443 to repair. Not comfortable with answer that an assy in the door is not owrking and the door wont open. Is this probable? Hate to spend $443 and that not fix the problem. They also said latch assy must be programed at the dealer for it to work. Im confused. Any suggestions?
Steve,
My 2008 Tahoe has developed the exact same problem you have. I get the same clicks and whirs, but no raised lift gate!! Have you found an answer yet?:cool: |
see above reply
see the above reply. Nothing else new yet. Really cant believe its the latch assy though. Waiting on a nephew thats a mechanic to tell me more.
(Post 229356)
switch
I found the switch early on but it maked no difference. Im gonna check it again though to make sure. Thanks
Any updates to this? I have the same problem with my 2007. Console, remote, or rear hatch button all do the same thing... latch unlatches, but I have to pull the door a bit or it will re-latch. The auto lift does not engage. I hear it, but it does nothing. I had to pull it and would feel it disengage.
I have also heard that it could be the electronics in the latch mechanism that is not telling the lift to lift. The latch does make all kinds of noises and sounds like it cannot make up its mind what it is doing upon opening. I am about to list to sell, but want to fix this before I do. |
| All times are GMT -5. The time now is 1:40 AM. |
