2007 key fob problem
Old Aug 13, 2014 | 7:27 PM
Dropdprpls10's Avatar
Default 2007 key fob problem
i need help.. I’m at a loss here.. the remotes to my 2007 suburban LTZ only work if you put the key in the drivers door and unlock it.. i did a relearn and pulled the fuses... stil does it...
Old Aug 13, 2014 | 11:13 PM
What???
No sure I understand this. Do mean the powerlocks only work by the key in the door or as written.... the fobs only work with the key in the door lock cylinder?
Old Aug 14, 2014 | 4:26 AM
remotes will only work after you put the key in the drivers door and unlock it with the key..
Old Aug 14, 2014 | 7:45 AM
{tpc}'s Avatar
That is an odd issue. I can't see why the movement of the door lock would do anything, but maybe the receiver for the fob is going to sleep when it should not be and then waking up somehow from the movement. Then the fob starts working.
Are this replacement aftermarket fobs like off of ebay or original? I bought a second fob for mine off ebay and it mostly works....everything except the rear hatch opening. So that might also have something to do with it.
Old Aug 14, 2014 | 8:13 AM
I did buy new remotes off eBay when I bought the truck a year and a half ago. I got new remotes because the remote start wasn't working. Later found the remote start sleep mode. This problem just started this week. I think I might still have the old remotes. Maybe I'll try relearning them.
Old Aug 18, 2014 | 6:11 PM
Well to follow up. I disconnected the battery for a few minutes to try to reset the computer. And it seams to work now.. Smh...
Old Aug 19, 2014 | 7:44 AM
{tpc}'s Avatar
Glad its working again. I wonder if your battery(s) (car or remotes) are starting to degrade and thats why the problem is occurring? Food for thought I guess.
Fox1311
Mar 15, 2019 6:50 PM
kcarberry
Jan 24, 2014 5:37 PM
chevykicksbut
Oct 23, 2010 12:32 AM
djudkin
Aug 9, 2007 12:53 PM
