2007 Power Source
Old Jan 2, 2007 | 1:06 PM
  #11
cmwoody's Avatar
Default RE: 2007 Power Source
ORIGINAL: TMW597
retained accessory power.
Stupid question...whats that? Is that like the radio, stays on untill the door is opened power? Thinking the pigtail on the fuse block thats there for the headrest DVDs is maybe the source you need. Not sure, just switched mine over to that. I'll check and let you know.
Old Jan 2, 2007 | 1:43 PM
  #12
TMW597's Avatar
That's exactly what it is. Allows power to the head-unit, windows etc. until you open up the driver's door.
Please let me know your results and if you find that "tap".
Old Jun 29, 2007 | 11:19 PM
  #13
haidangwa's Avatar
I wish the power outlets were also connected to RAP, instead of always being on. I can't tell you how many times my wife has left the portable Garmin plugged in and on all day! We have another vehicle (uh hum...not a Chevy) that gives me two outlets up front -- one is always on, the other is RAP.
Old Oct 8, 2007 | 11:15 AM
  #14
TMW597's Avatar
Just revisiting this post. Has anyone found a retained accessory power source in the 2007 Tahoe?
Old Oct 9, 2007 | 11:43 PM
  #15
15 Year Member
I thought there was a previous post that said there was one available under the right (psgr) side of dash on the side that faces the door.
Old Oct 10, 2007 | 6:21 AM
  #16
McGuireV10's Avatar
It's pointless of me to say so, but I've always thought 12V sockets should have been designed with one always-on and one ignition-driven connection point so that the plug itself would determine whether switched power was required.
But "they" don't ask me, LOL... otherwise I'd have Bluetooth and 110V outlets in my Suburban...
Old Oct 10, 2007 | 6:55 AM
  #17
e's Avatar
e
2007 Toyota Tundra has the two power points in the front console set up this way. Ones 12v constant and the other 12v Ign. I know a meaning less post..........
Old Oct 10, 2007 | 12:54 PM
  #18
McGuireV10's Avatar
Actually, I meant each 12V plug should be designed to supply both switched and unswitched power. But I suspect it's pretty unlikely that such a well-established standard would ever be changed.
Old Oct 11, 2007 | 1:45 PM
  #19
Islanti's Avatar
ORIGINAL: McGuireV10
I don't know... there was a lot of talk a few years back about changing the in-car standard voltage to 24v. Might still happen.
Old Oct 11, 2007 | 3:49 PM
  #20
AZSCTACO's Avatar
Here ya go.....
