Old July 22nd, 2015, 2:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Towing and Hauling
Print Wikipost
2007 Suburban 1500 2WD towing issues
Old April 5th, 2014, 11:39 AM
  #11
Jeremy3040's Avatar
would bet money the tongue weight is off......glanced through thread and seen good ideas but maybe you have too much weight as well on the tongue. Absolutely get all tire pressure correct and trailer as well first.
Old April 6th, 2014, 9:03 AM
  #12
intheburbs's Avatar
Originally Posted by Jeremy3040
...but maybe you have too much weight as well on the tongue.
No offense intended, but this is absolutely dead wrong. Sway is caused by insufficient tongue weight, not too much.
Too much tongue weight is just as bad as too little, but for other reasons. This is directly from the GMC website:
If you don't have enough weight on the trailer tongue, less than 10 percent of the total loaded trailer weight, the trailer can end up swaying from side to side, making it difficult to control. If you have too much weight on the trailer tongue, more than 15 percent of the total loaded trailer weight, it can overload the rear tires and push the rear of the vehicle around. You might not be able to go around corners and curves properly, and your vehicle might not stop fast enough when you press the brake pedal.
LINK
Old April 6th, 2014, 9:50 PM
  #13
Jeremy3040's Avatar
LINK
None taken……learning all the time.
Old April 6th, 2014, 11:43 PM
  #14
SWHouston's Avatar
Default Trailer Tongue Weight
Those percentages are accepted rule of thumb...
10% for just about every type trailer except...
15% for Travel Trailers. (I think that's because there somewhat top heavy)
It's always a good idea to get your loaded Trailer weighed (separate from vehicle) and know what you have back there, regardless of the type. Then, you know exactly what the tongue weight should be, and adjust Tongue load accordingly.
robuga
April 11th, 2014 9:08 PM
beaver2low
November 24th, 2013 11:56 PM
Captain Amerika
August 20th, 2013 5:27 PM
missouriboy1
July 25th, 2013 4:44 PM
Quick Reply: 2007 Suburban 1500 2WD towing issues
