2007 suburban ltz, loss of power while driving
Old Nov 8, 2019 | 12:36 PM
chris1991's Avatar
Default 2007 suburban ltz, loss of power while driving
2007 Suburban LTZ 4WD 5.3L 165,000 miles
while accelerating im experiencing loss of power and the rpms drop with throttle engaged. I let off throttle and re-engage and im good if im conservative with the throttle.
Now the same problem as above occurs, but I am now getting the "Stabilitrak Off" light popping on. when I let off the throttle the light went off and the RPMS went back up.
I just got this thing and im up in arms
Last time it was low on fuel, and after I filled it up it was fine.
this time I have a little under an 1/8th of a tank and it just started happening.
could this simply be a "low fuel" problem?
I have codes:
1. C0900
2. C0899
3. C0561
4. P0171
5. P0174
Old Nov 8, 2019 | 8:30 PM
oilcanhenry's Avatar
I have codes:
1. C0900
2. C0899
3. C0561
4. P0171
5. P0174
Likely an intake manifold gasket leak.
Also might be:
Mass Air Flow Sensor. MAF
Bad Fuel Injectors
Fuel Pump/Fuel Filter bad
Might want to check your battery connections too.
Old Nov 12, 2019 | 8:07 AM
chris1991's Avatar
HI oilcanhenry,
after this occurred I filled it with gas and some sea foam, since that, which is a few days ago now, I have not had the issue.
I am not sure what that means?
Old Nov 12, 2019 | 8:55 AM
Irish_alley's Avatar
I'm here for the party
a low fuel problem might be due to a fuel pump issue and the fuel might be covering it up once you add fuel.
bamspringtx
Aug 7, 2024 9:52 AM
farmall130
Sep 3, 2014 8:43 PM
bfd811
Mar 24, 2014 9:12 PM
jeffs_62
Jun 15, 2013 11:55 PM
jonze_11
Jan 26, 2011 8:49 AM
