2007 Superchips ? What is your programmer set on?
Old Jan 9, 2007 | 2:11 AM
biglg's Avatar
Default 2007 Superchips ? What is your programmer set on?
Hi,
I just got my Superchips 2815 for my 2007 Tahoe today. I was a bit surprised that the options are very different from the superschips I have on my Dodge Ram.
So, I messed with the settings a bit! But havnet had much time. So those of you who have had yours for a while and have tried out different setllings can youtell me what you have your superchips set on, what you think fits the best and provides the best performance. Thanks.
Old Jan 9, 2007 | 3:15 AM
Clay24's Avatar
Default RE: 2007 Superchips ? What is your programmer set on?
Big Lg just set it for the highest setting and give her H let us know what the seat of the pants feel is
Old Jan 9, 2007 | 12:00 PM
Black 5.3's Avatar
verycool.. Biglg what are the parameters available to you?? do you have wheel sizeadjustments yet and what other options are in the programmer
Old Jan 9, 2007 | 12:02 PM
biglg's Avatar
ORIGINAL: Clay24
NOT A CHANCE IN HELL!
Old Jan 9, 2007 | 12:05 PM
biglg's Avatar
ORIGINAL: Black 5.3
Well, I have had superchips before. This one is a lot more detailed/technical than my previous flashpaqs.
The reason I bought it is for the tire size adjustments, it has this feature.
You can change the rev limiter, speed limeter, tire size, and change the shift points of each shift. Ex: 1-2 gear by .5MPH 50RPMS, 1MPH 100RPMs, etc for each gear shift. Then you can change the gear shift PSI!
My last superchips didnt have the increment shift changes and shift PSI. So I am looking for someone that has found the best set up. When I had the dodge there was a perfect range that provided the best performance. Just wondered if anyone has tooled around with one yet and found this information out.
Old Jan 9, 2007 | 1:55 PM
Black 5.3's Avatar
im with Clay24 go for the highest settings in the tow/haul mode and leave the normal shifts stock so you can have two different settings with just a press of a button
Old Jan 28, 2007 | 2:46 AM
t2's Avatar
t2
Have you seen any problems with the fuel management system switching between8 and 4 cylinder mode with your Superchip programmer?
Old Jan 28, 2007 | 11:04 AM
biglg's Avatar
Nope, no problems at all. If anything, it seemsto run in v4 more often.
Old Jan 28, 2007 | 11:54 AM
P_RsTahoe's Avatar
Did it bring a performance set up? How many programs came with the tuner. I had a predator for my old 03 and I went with the one that was labeled performance. But after that I had to run premium gas. Is that the same? How much for the programer? Thanks.
Old Jan 28, 2007 | 1:20 PM
dirtywork's Avatar
Hmmmm....sounds tempting! Let us know Biglg once you set it up and what your experiences are.
