2007 Tahoe ABS Computer Controller
Old Dec 10, 2013 | 8:58 PM
  #11
any shop with a genysis or full function scan tool can do an auto bleed. You don't have to go to a dealer.
Old Dec 10, 2013 | 9:30 PM
  #12
titantn24's Avatar
Originally Posted by rnorman4
I like that strategy, but you know the garage here will probably charge me $150 to bleed the brakes and $120 for the scan...that's 1/2 the friggin cost.. I'll let you all know how it turns out...with pictures.. PS I tried to take the computer off the pump unit...not good, the torx bolts were corroded and seized into the aluminum block and broke off f&%k. Anyways, inside it all looked good! Couldnt' get the computer side cover off the EBCM, it seemed gluded on or something, but the side with all the solenoid coils looked good... I put it back on with the 2 screws that didn't break, along with a good all around seal of JB weld! WTF right? No other way, the broken studs would not come out...the only other way is to replace the entire unit. Picture attached...no worries, JB weld is awsome, the seal is good. Next time though the entire unit needs to be replaced...ABS light is still on ofcourse, still no 12V at the sensors.
Man, it sure is rusty under there! I can see why those bolts broke off. You must drive where a lot of road salt is used.
bobinpa
2007 - 2013 (GMT900)
37
Jan 3, 2016 7:45 PM
reedbr
Aug 16, 2014 8:41 AM
Rescue30
Jul 6, 2010 3:48 PM
kalle1066
Sep 20, 2007 10:29 AM
Heavysledz
Oct 24, 2006 9:00 PM
