2007 Tahoe A/C compressor cuts in and out
Old Aug 2, 2012 | 4:04 PM
rnorman4's Avatar
Default 2007 Tahoe A/C compressor cuts in and out
Hi all, my 2007 Hoe, when I turn on the AC at the dash the center of the compressor under the hood begins to turn (I assume the electric clutch is then working), it stays spinning for about 5 seconds and stops, then again 10 seconds later starts again, and then stops, etc...etc...like that. No cold air at the dash at all. Seems like the system might be turning on and then sensing that there's not enough pressure maybe???and then turning it's self off again? I haven't checked the system refrigerant pressure, and have no idea how, if you think that's the problem should I check it or just bring it in for service? Or should I attempt to check the refrigerant (134a) or the PAG refrigerant oil level? Or maybe the compressor is shot?
Thanks!!
RN
Old Aug 2, 2012 | 6:20 PM
Sounds like the low pressure switch may be kicking off the compressor due to low refrigerant. If you have no idea how to check, then I'd advise you to have a qualified shop check it out for you. If it's that low, then probably a leak somewhere that'll need to be fixed before adding expensive R134a.
If you decide to DIY, you can pick up a set of gauges at Harbor Freight for about $60. But if there's a leak, then you'll probably still need to take it in.
Old Aug 3, 2012 | 10:35 AM
Official GM Rep
Thanks!!
RN
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I'm sorry you are experiencing this issue with your Tahoe vehicle. I agree with "73shark", and encourage you to have the vehicle inspected by a certified technician. They will be able to offer an official diagnosis, and repair options, after inspection.
Please keep us posted.
Louis
GM Customer Service
Old Jul 27, 2013 | 7:42 AM
rnorman4's Avatar
Default AC Leak
Thanks louis, I finally got this checked out. There appears to be a leak in the "rear pipes"?? According to the garage. $1700 fix!! WTH. I didn't get it fixed and am investigating fixing it myself. ANy idea where to get a complete picture of the layout etc... of the AC system in the '07 hoe?
Thanks!
Bart
Nov 25, 2021 9:36 AM
ainkurn
Dec 23, 2020 8:57 AM
flynhayn
Jul 22, 2011 9:35 AM
joshkruger
11
May 23, 2008 12:25 PM
k10sport911
Jun 27, 2007 4:01 PM
