2007 turn button 4wd
Old Sep 17, 2018 | 2:23 PM
joey85's Avatar
Default 2007 turn button 4wd
When backing up and turning right the 4wd will go into 4low when i start to move its in 2hi though. 4wd low indicator is on and you can feel front end bindning (4x4 binding). Anyone have similar issue
Old Sep 17, 2018 | 6:25 PM
oilcanhenry's Avatar
Probably a bad transfer case encoder....if you are lucky. Do you hear any strange noises from the transfer case area?
Old Sep 18, 2018 | 6:37 AM
joey85's Avatar
no strange noises at all and other wise drives very very well
Old Sep 18, 2018 | 3:34 PM
Has the transfer case had a fluid change done or levels checked?
