2007 Yukon key fob programming
Old Jun 11, 2020 | 3:35 PM
Brad O's Avatar
Default 2007 Yukon key fob programming
I have an 07 Yukon SLT. My DIC display went out and I haven't been able to get it repaired.
Is there any other way to program new key fobs without using the DIC menu?
I've read about long pressing the trip odometer reset but wasn't sure if that method would work in this instance.
Old Jun 12, 2020 | 7:14 AM
Try it anyway. It still should work even if the display is not working. The display is just letting you know that it is in programming mode. It is worth a try.
Old Jun 12, 2020 | 8:08 AM
Brad O's Avatar
Thanks for the response.
I realize the DIC would work without the display. Just wasn't sure how to navigate to the relearning point blindly. Along with being concerned I might accidentally change other settings in my attempt. So I was looking for an alternative method.
But you're right. It's probably worth a try anyway.
After watching some YT videos, when using the DIC , it seems like it's 6 presses of the second button and then select to get to the programming.
​​​​​​​Could anyone with a similar year model verify that?
Chevytahoeredneck93
Jun 30, 2014 1:56 AM
Mr. V
Sep 24, 2010 10:58 AM
bigtim
Apr 16, 2008 11:06 PM
36master
Nov 3, 2006 11:18 PM
36master
