2008 Chevy Suburban Decide
Old Jun 23, 2021 | 12:14 PM
Harrisal21's Avatar
Default 2008 Chevy Suburban Service Charge System Message
I've been fighting a Service Charge System Message for awhile now. It all started with headlight flickering. Battery and alternator was tested alternator checked out but battery was showing weakness. So replaced the battery's then started getting the service charge system message. Replaced the alternator to no avail. Checked my connections and all is good. Now it's only intermittent at idle then goes away after driving. Sometimes it won't appear at all. With the scan tool I get a P0622 (Generator Field F Circuit Malfunction) code stored.
Old Jun 24, 2021 | 6:54 AM
repairman54's Avatar
Check your grounds. There are several grounds to frame under the truck also and multiple connection grounds. Remove and clean thoroughly. Especially the PCM grounds.
Do a search on grounds here as there are many posts that cleaning grounds fixed a lot of weird problems.
Was your alternator a reman. or new. Lots of remans are junk so don't discount that. Low alt. output at idle is a sign of worn brushes in it.
Typerod
Feb 8, 2019 7:46 AM
OptimusPrime
Traverse
Jun 21, 2017 7:48 AM
EMT4Site
Mar 29, 2017 8:09 PM
jlockler
Jul 8, 2013 5:30 PM
JC2133
Feb 19, 2012 11:40 AM
