2008 tail light issue
Old May 13, 2014 | 1:47 PM
4x4tx's Avatar
Default 2008 tail light issue
Tail light stopped working..took it off and plugged into the other side and it works....so seems to be a short...anyone have any ideas?
Old May 15, 2014 | 9:42 AM
Have you added any aftermarket wire harnesses/trailer lighting ?
Checked all the fuses ?
Checked the underside of the rear quarter panel for any damage to the wire-harness?
Old May 16, 2014 | 10:05 AM
4x4tx's Avatar
No aftermarket anything....haven't checked fuses, does that make sense when the brake, turn etc functions work? Where is the fuse box?
and yes I unplugged the wiring harness from the left side and took it over to the right to plug into that harness and it works over there.
Old May 22, 2014 | 8:46 AM
4x4tx's Avatar
Thoughts?
Old May 31, 2014 | 2:02 PM
4x4tx's Avatar
does anyone know of one of the wires is specifically for the tail light funtion? Could it a prong of of the plug or just a bad wire? Anyone now the color coding of the wires?
Old Jun 2, 2014 | 9:05 AM
SabrToothSqrl's Avatar
Default fuses
I'm still leaning towards fuses... you checked them?
Old Jun 3, 2014 | 10:03 AM
4x4tx's Avatar
I have not, I tried to figure out which fuse would be the one I am looking for but I could not tell. Anyone know?
Old Jun 23, 2014 | 8:56 AM
4x4tx's Avatar
checked fuses and they are good...appears to be a wiring issue unfortunately
Old Jun 23, 2014 | 8:48 PM
4x4tx's Avatar
Tested sockets good....wiring at harness good....does anyone know which color wire handles the tail light?
Old Jun 24, 2014 | 8:45 PM
Factory909's Avatar
Check the connector underneath the truck near the spare.
