2009 Suburban with 2 issues.
Old Apr 16, 2018 | 7:53 PM
RDriskill's Avatar
Newly Registered
Default 2009 Suburban with 2 issues.
I am having problems with my door locks working intermittently. The rear door locks don't always unlock. Also, I intermittently get a service ride suspension message. I am wondering if both of these could be related to a bad BCM?
Old Apr 17, 2018 | 8:27 AM
probably a separate issue as the air suspension uses a separate module. if there is a fault with the system, codes will be stored in the module. A code reader cannot access them; you need a full function scan tool.
the door lock actuators are famously bad. if you are getting power to the actuators, replace them. gruvenparts, a member here makes a replacement part
