2009 Suburban misfire #6
Old Nov 15, 2024 | 3:35 PM
fmt2bx's Avatar
Question 2009 Suburban misfire #6
Hi,
I have a 2009 chevy suburban 5.3L LC9 engine, no AFM system.
I am getting a constant misfire on number 6 P0306 DTC.
So far:
- Swapped , coil, plug, plug wire and injector from #1 to #6.
- Checked good spark
- Compression 150# (getting about the same on other cylinders)
- NOID light on #6 injector, checked ok.
- Using Tech2, did an injector balance test, #6 similar to all other injectors. Good pulse and press drop similar to all others.
- Checked for collapse lifter and lifters checked ok.
- Did a leakdown test on #6 (and #1 for comparaison), no leak on #6.
Still misfiring continiously on #6. ????
What else can I do? I am at a complete loss...
Thank you.
Georgeb12
May 11, 2024 9:50 PM
dagger1982
Jul 15, 2023 5:07 PM
WiseMountainApe
Jul 13, 2021 9:41 AM
KAllan
Jul 9, 2012 8:22 PM
cnterline
Feb 15, 2009 9:06 AM
