2011 Chevy heated steering wheel
It's not possible. My '11 Tahoe LTZ has 41 control modules in it. My truck has every factory option in it. Every feature or option has a computer-controlled module to run every option through the CAN network. No heated wheel option in '11 so there is no way to add in a heated wheel with correct factory controls. A complicated ''hack'' may be possible but for heated wheel its not worth the giant hassle. A pair of gloves is cheaper and easier.
If It could be done simply I would have done it a long time ago.
dealer wanted $1,400.00 to replace heated wheel…I can’t afford. Just want to cut power to wheel
So nobody turns it back on and it starts smoking again. Dealer confirmed heating element has short.
dealer said they wouldn’t disable power to the on/off button.
the owners manual should describe what the fuses do.
A quick forum search seems to get the info you need:
https://chevroletforum.com/forum/tah...12/#post199028
https://chevroletforum.com/forum/tah...460/#post48825
A quick google search got me a copy of your steering wheel schematic:
https://www.slideshare.net/fjjfyjsek...nual-244825995
at numerous documents and YouTube videos specifically labeled 2012 and found them to vary. I find the 2007
schematic hard to interpret…I am not an electrical guy. I can’t even figure out how to find the two “posts”
you refer me to.
chances are it'll be close enough
what do you mean? Clicking the links should take you straight to them
so you should probably leave the job to somebody who is.
If I remember correctly, the fuse for my heated steering wheel was along the steering column.
The shroud around the column, which covers the turn signals switch must be removed, and an inline fuse should be visible.
I just finished this mod on my 09 Silverado 1500.
No BCM programming required.
Other than the wheel itself, the other parts I needed were a new clock spring (with the wiring for the heat,) gm part 25966964, and a pigtail from ssconnectors.com, part 60296271.
This clock spring is for 1500's with a 2 stage airbag.
Hope this helps!
Hope this helps!
