2011 Heater just stopped
Old Dec 30, 2017 | 3:02 PM
mstewart39's Avatar
Default 2011 Heater just stopped
2011 suburban LT.
i am in Buffalo NY and it's about 5 degrees. I drove with the heater on, and it said "engine hot, turning off AC" or something like that.
Now i cant get any heat out of it. The HVAC only blows cold air. (But it could be because it's only 5 degrees outside.)
Any ideas what happened? Or what I'll need to do to fix it?
Old Dec 30, 2017 | 3:48 PM
Rednucleus's Avatar
Were you running and up to temp and getting heat when this happened, or did it go from a cold start?
Last time you checked your coolant level and freeze level protection?
Old Dec 30, 2017 | 3:52 PM
oilcanhenry's Avatar
Originally Posted by mstewart39
2011 suburban LT.
Try blocking the radiator with something like cardboard. Block half of it. If it warms up you probably have a bad thermostat. Thats an easy fix.
Old Dec 30, 2017 | 7:41 PM
mstewart39's Avatar
Running and relatively warm. But it quickly stopped. I've never checked actually. But I only had this suburban since February.
Old Dec 30, 2017 | 8:59 PM
The temperature gauge should indicate about 200° F when it's warmed up. The A/C compressor will not turn on when the outdoor temperature is below about 38° F. This is to prevent the evaporator from freezing up.
Old Dec 30, 2017 | 9:59 PM
mstewart39's Avatar
I just drove it again, and it was around 245 degrees most of the time. When I put the defrost on, it would go up even higher.
Might that mean I am low in coolant? When it got closest to 250 it gave me the error again that the engine was too hot so it was shutting the AC off.
I believe there is a little garage around here that is open Sunday. I hope. I’ll check the coolant when it’s light out, and then maybe take it somewhere if possible. Ugh. I have a 6 hour drive on Monday!!
Old Dec 30, 2017 | 10:55 PM
I'd make sure you have enough coolant.if you have a kitchen thermometer it will work to show the temp of the coolant. 245 degrees is much too high.should at least 185 to 195 F ,not 245-250 F.,
Old Dec 31, 2017 | 12:00 AM
Suburban Dude's Avatar
I agree that 245 F is way too high, but the normal temp for a Gen IV 2011, is 210 F, higher than the Vortec engines from the 90’s. They will run at 210 regardless of the outside temp. It’s 5 F outside righ now, and my engine temp on my 6 liter 2008 was 210 F.
Old Dec 31, 2017 | 3:08 PM
mstewart39's Avatar
I put about a gallon or so of coolant in and now everything seems back to normal. We couldn't find any leak, so hopefully it's good. I'll get it pressure tested in a couple days. It's running right at 210 degrees.
Thanks for the input!!
Old Dec 31, 2017 | 3:56 PM
Check the underneath side of the oil fill plug and see if it has any jellied oil on it. If it does, then it's got a leak into the internals of the engine.
FWIW my 2007 and 2010 both ran straight up at 200° F.
