2011 Suburban entire truck shakes when applying the brakes
Old Apr 2, 2019 | 2:19 PM
Ryan Harris's Avatar
Default 2011 Suburban entire truck shakes when applying the brakes
I've been searching high and low for the answer to my problem and cannot find anything. My entire truck shakes when applying the brakes, like the ABS is engaging then disengaging over and over until I come to a complete stop. I've replaced all rotors and pads and it's still happening. Every shop that i've taken it to can't figure out the problem, just wasting money at this point trying to figure out what the problem is. I'm not made of money and this has put a huge burden on my savings acct, willing to just trade it in and get something different that isn't Chevy. Anyone have this same issue and figured out what it is causing the shakes? I've read multiple forums and can't find a common solution.
Old Apr 2, 2019 | 3:17 PM
Irish_alley's Avatar
I'm here for the party
just an idea but cant you disengage the abs and see if it happens? i know on my 04 imp if a had a bad wheel sensor it would disable the abs. maybe unplug a wheel sensor and or maybe disable the stabilitrak by holding the trac control button for a few seconds (want to say 5 or 10)
Old Apr 3, 2019 | 6:00 AM
Once I get the truck back I will give this a shot.
Old Apr 3, 2019 | 8:11 AM
Things that come to mind:
Warped rotors
bad wheel bearing or hub
U-joints
motor / transmission mounts
bad or loose shock mount
worn or missing sway bar links or bushings
These are items I'd check as any of them could cause an unusual balance or twisting that could put something out of alignment that could also cause shaking when braking.
As a side note, be sure you are using the correct torque setting for your wheel lug nuts, otherwise the rotors can warp from uneven wheel stud pressure. this is a very common mistake folks make.
