2012 Suburban 5.3 4X4 metallic rattle
I have noticed a metallic popping sound when turning at times. Might be described as the sound of bolts moving around in a metallic container. The location seems to be on the driver's side near the front wheel. Are there any known problems with front suspension/steering/brakes??? The sound is not heard in every instance of turning, just every so often.
Any feedback appreciated.
Check you front struts. Make sure they a tightly bolted in, both top and bottom.
I upgraded to bill steins a few years ago and they made a sound because they were not tight.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> fishingfanatic,
I’m sorry you are experiencing this issue. “blueinterceptor” offers a possibility. Another possibility is a loose wheel nut cab. This is just a suggestion and it not meant as a diagnosis.
I recommend consulting with a certified technician for an official diagnosis after inspection.
Please keep us posted.
If you have additional questions or concerns, please feel free to contact me.
Louis
GM Customer Service
Louis
GM Customer Service
hamonbagel
May 19th, 2015 1:55 PM
JustinL
August 23rd, 2014 12:54 PM
gjohnson25
October 31st, 2011 11:42 AM
