2012 Suburban center console wiring
Old Aug 2, 2013 | 11:58 AM
tigger5's Avatar
Default 2012 Suburban center console wiring
Hi
Installed a halo light controler in the glove box and would like to tap into a power supply that runs with the key on. Under the center console cup holders/tray is a wiring harness that I am guessing supplies the cigarette lighters and heater/radio controls for the 2nd row seats. Is there anything in here I can use and if yes which one (color/connector) ??
If not, I have an empty fuse holder in the instrument fuse panel block for "cooled seats" (fuse number 24) which I do not have, can I use this without any consequences to anything else??
Old Aug 3, 2013 | 4:22 PM
tigger5's Avatar
Well I found a solution...involves hooking up tp the power out at the engine fuse block (posts with "always on" power), a relay and a power source next to the parking brake pedal that has a low power out with the key on...have pics if needed....
AnnaRiling
Oct 3, 2023 12:24 PM
Danistheman1234
May 18, 2011 10:49 PM
Danistheman1234
May 14, 2011 8:55 PM
timsalive
Dec 11, 2010 9:57 PM
suitedandbooted
Jan 3, 2008 2:35 PM
