2013 Suburban Transmission Control Module
Old Jul 24, 2025 | 3:55 PM
Xylophoneman's Avatar
Default 2013 Suburban Transmission Control Module
I am getting code P0700 on my new to me Suburban and have noticed some erratic shift. I have tried resetting the module via the numerous way the internet suggests and I have added instant shudder fix to the fluid. The fluid is new as it was replaced less than 1000 miles ago via flush. Is the TCM something I can buy and replace myself? If so where is this thing located and what will it take to get to?
Old Jul 25, 2025 | 11:30 AM
Buste6677's Avatar
Default Tcm
Hello for some reason people don't respond here I will ..The TCM is in engine compartment drivers side on the front of the inner fender well firewall side the the ecu will be facing the radiator as well . Yes you can change it but as with changing any module it needs to be programed/ flashed .that you can also DIY if equipped properly and buy a program yourself..
David Dauenheimer
Jul 25, 2025 11:40 AM
Kmink1967
Sep 2, 2024 8:32 PM
mountainmanjoe
15
Mar 23, 2022 12:31 AM
Shunter
2007 - 2013 (GMT900)
Mar 21, 2022 8:57 PM
samyar
Aug 2, 2015 10:16 PM
