2014 Transmission diagnosis
Old Jan 21, 2026 | 6:39 PM
brcisna's Avatar
Default 2014 Transmission diagnosis
Hello All,
2014 1/2 ton 2WD Suburband 135k miles. Looking at this vehicle to possibly buy.
The truck,, hesitates to take off in drive but will eventually 'kick in',,,and once it gets rolling it shifts through all the gear normally with no strange noises. When you pull up to a stop sign,it feels like it goes into neutral,,,,then if you feather the trhottle it will catch,,and take off from stop sign,,and shift through the gears normally again. Reverse works fine with no hesitation. No codes on the dash.. Didnt take a scanner with me when i looked at the truck,,,stupidly. Sort of acts like just low on fluid but fluid was up to correct fill on dipstik.
Any trans gurus,,,that may have some suggestions.
TIA
whitesnowden
Oct 25, 2014 2:24 AM
rubydsouza
Jul 29, 2014 6:24 AM
pfcpritchett@gmail.com
May 24, 2014 7:08 AM
Xtreme2358
Jan 20, 2014 5:43 PM
New truck every 15 years
Nov 11, 2013 1:02 PM
