2015 Suburban - Front AC blows hot, rear AC works fine
Old May 17, 2017 | 12:15 PM
Kinalyx's Avatar
Default 2015 Suburban - Front AC blows hot, rear AC works fine
Not sure what is happening at this point. The AC blows extremely hot during the day, but works fine at night when the outside temp goes down. The rear AC seems to be blowing cold as usual. This just started a couple days ago.
Shawn
Old May 17, 2017 | 11:59 PM
hard to say without some testing...maybe a bad front thermal expansion valve. Really need to check for dtc and have an a/c performance test done. This will provide temp and high/low side pressures. This data will provide a diagnostic starting point.
Old May 19, 2017 | 7:41 AM
Jennie Mcdonald Harden's Avatar
Default 2015 Tahoe AC Condensor on national back order
Not sure why the AC condensers are not on the recall list. Dealer said delivery is anticipated in 30 days or so and $800 to replace the faulty cracked condensor. Today's weather forecast is 92 degrees and thunderstorms with hot air blowing out of my ac vents. Not A happy camper!
Old May 19, 2017 | 8:50 AM
start a new thread instead of hijacking this thread
