2015 suburban lt not starting after run for 1 hour
Old Jun 15, 2024 | 4:25 PM
Mapercas79's Avatar
Default 2015 suburban lt not starting after run for 1 hour
For some reason after the transmission was replaced on my suburban I started with this issue, the suburban starts good when is cold but after ran for like 1 hour if I shut it off it won't start right away I have to wait like 30 to 45 min and then it starts running again.
Do some body had this issue before? And got it fix?
Old Oct 22, 2024 | 7:16 AM
Rob12Bravo's Avatar
Default Hello Mapercas, were you able to find out the problem? My 2015 suburban does the same
Hello where you able to find out the issue? My 2015 Suburban does the same after running it, I shut bit off and won’t start again till after 30 min of parked ?
Old Oct 22, 2024 | 8:42 AM
Cusser's Avatar
Starter fails to crank/spin engine ?
Starter cranks/spins engine but engine won't start?
These are entirely different situations, and you didn't even clarify to us !!!! So you just wasted my time.
chiefsport
Oct 26, 2025 2:17 PM
Cumminsspitfire
Jan 8, 2023 11:19 PM
Tanzi411
Nov 10, 2022 3:56 PM
Aaron Heimbecher
Mar 26, 2020 6:33 PM
libgentech
Oct 12, 2017 5:26 PM
