2015 Tahoe LTZ Electrical Issues
Old Jan 1, 2024 | 12:40 AM
glecoq's Avatar
Default 2015 Tahoe LTZ Electrical Issues
So…I have a well-maintained 2015 Tahoe LTZ. About 6 months ago, the “Trailer Brake System” began intermittently throwing a warning at me during a drive (warning on, then turn off a few minutes later). Strangely, that problem seemed to disappear for about a month and then the “BIG PROBLEMS” began.
Out of nowhere, and intermittently, the car would throw a whole slew of driver assist errors. This included Stabilitrak, suspension, trailer brake, power steering (none—slightly different later, stay tuned), park assist, adaptive cruise, and possibly some others in forgetting. Took it to a trusted mechanic. First thing needed was a new battery, so swapped that. Car ran smoothly!…for a week. Then the same issues. Took it back. They determined it was a bunch of corroded connectors and wires. So, they cleaned them up. The car ran smoothly! …for a week. Then the same issues. Took it back. They determined it was more wires, some “harness,” and the trailer brake module. They replaced. The car ran smoothly! …for 450 miles. Then ALMOST the same issues (no Stabilitrak warning this time). Took it to the dealer. They said the negative wire from the battery was drawing too much power. They replaced it. Car ran smoothly! …for one day. Now I’m 450 miles from home, thousands of $ poorer, and I’m still in basically the same situation as I started in. Ugh.
The current errors displayed are suspension, trailer brake, adaptive cruise, and steering assist (at this point it will EITHER be “reduced” or none…no rhyme or reason as to which of this happens), and sometimes the park assist (the lane departure doesn’t display any warning but it also won’t work). The lights displayed IF the issues crop up are the parking brake, the ABS, and the traction control lights. With the exception of the park assist, all of the above will happen together or none of it will happen. I
t’s SUPER intermittent. Sometimes the car starts and there are zero issues. Sometimes it starts with all of the above. If that happens and I wait a 15-30 minutes and try again, it can work fine again. The only other weird things I’ve noticed are the sensor for day/night seems to not work as well when these issues are happening and the front proximity sensors seem to notice things that are not there (for example, when at a stoplight, it will display something being close when there’s nothing). These two seem things are “issues” if the above errors are present during a drive or not. No clue if this is related.
So, any ideas…??!
Old Jan 11, 2025 | 9:31 PM
Eknockout's Avatar
So, any ideas…??!
Did you figure it out if had same issues replaced negative cable
Old Jan 12, 2025 | 12:46 AM
glecoq's Avatar
Yes, after nearly losing my mind over this, working with two dealerships who were entirely unhelpful, I returned to my original mechanic and had them watch the below video that another user shared with me. They spent time learning from it and proceeded to properly diagnose the issue which was the same as in the video but more widespread: multiple corroded ground connections (I’m not smart enough to describe in any greater detail than that). Many thousands of dollars of labor later and it’s been running smoothly (knock on wood) for about 9 months now.
brinson
Nov 2, 2023 12:23 PM
Rsmall21
2014 - 2018 (GMT-K2)
Sep 1, 2017 2:10 PM
coleman06
Jul 29, 2014 2:29 PM
ragin_cajuns
Feb 6, 2008 8:50 AM
