2016 Tahoe LS Change Bearing... Now Stabilitrak & ABS!!!
Old Jan 30, 2020 | 7:58 PM
RichardP's Avatar
Exclamation 2016 Tahoe LS Change Bearing... Now Stabilitrak & ABS!!!
Hello Everyone!
I just recently changed the right front bearing on my 2016 Tahoe and the Stabilitrak and ABS lights came on my dash. The truck is driving perfectly fine as it did before. I've tried clearing the Code with a cheap little scanner and even removed the battery for 4 hours. I thought maybe there's was something wrong with the bearing and also replaced it again and the errors are still there. Can anyone help?
Thanks!
Old Jan 30, 2020 | 8:05 PM
Irish_alley's Avatar
I'm here for the party
im not familiar with these newer trucks so im not sure if theyre set up the same way as the older ones, but did you inspect the abs sensor wire? did you try to clean it?
Old Jan 30, 2020 | 8:09 PM
RichardP's Avatar
I did check, clean and compared plug. I also checked the wire for any damage and it looks fine.
Old Jan 31, 2020 | 8:02 AM
Try taking the ABS sensor from the old hub and install it in the new hub to see if that solves the problem.
rhaibeck
Oct 5, 2018 7:56 AM
staceywilson2005
Oct 22, 2017 6:34 PM
mariaborja
Jun 19, 2017 11:39 PM
Josborne
Feb 11, 2017 9:37 AM
chino4allu@gmail.com
Aug 17, 2016 3:13 PM
