2018 Chevy Tahoe LT
Old May 29, 2025 | 9:43 AM
javierisaac22's Avatar
Default 2018 Chevy Tahoe LT
Hi - need some help please.
Went to start truck this morning and it didn’t start. Got a "click click click" noise. Figured it was the battery. Jump Started the truck and it quickly turned on. Drove to work. Everything felt ok. Except, the radio memory got deleted, and although I could switch between FM, AM and XM, and could hear it fine, I couldn’t see the stations or numbers and could not "save" a station under a given setting. When I arrived at work, turned off the truck, and decided to start it again just to make sure and same thing as earlier... No Start and "click Click Click”...
thanks for any guidance or info that can be provided.
Old May 29, 2025 | 9:49 AM
Rednucleus's Avatar
If it jump started I would be looking at battery 1st. Or alternator may not be charging. What was gauge showing once you got it started?
Old May 29, 2025 | 9:56 AM
OK Thanks. If you mean the Battery Gauge, it was showing normal at 13-14...
Old May 29, 2025 | 4:23 PM
Rednucleus's Avatar
13-14 suggests alternator is ok. Get battery load tested
Xjvhax
Jan 14, 2025 2:37 PM
Vacguy
Traverse
Nov 15, 2024 5:38 PM
olbrown327
Nov 19, 2023 10:57 AM
SaiRam
Dec 23, 2022 11:10 PM
Strobes
Sep 26, 2017 12:36 PM
