2018 Suburban - humming noise when driving
Hi all - I have a 2018 Suburban Premier. Over the last month or so I have noticed a humming sound when driving, which changes pitch as the truck accelerates and decelerates. Any thoughts on what this can be? My initial thoughts are bearings, trans, differentials, u-joints. Seems like too soon for any of those parts to fail. Thanks!
If you put it in neutral and it goes away, does it still exist? If it goes quickly away letting off the gas, it is sometimes rear end or drivetrain. If you swerve left and right you change weight on each side. Sometimes as you do that the sound gets louder as you put the weight on one side with the swerve. That usually is a wheel bearing
Big SUV
November 18th, 2021 12:33 PM
h3xc0re
February 27th, 2021 7:39 AM
