2018 Suburban - humming noise when driving
Old Sep 12, 2022 | 6:35 PM
Jason PM's Avatar
Default 2018 Suburban - humming noise when driving
Hi all - I have a 2018 Suburban Premier. Over the last month or so I have noticed a humming sound when driving, which changes pitch as the truck accelerates and decelerates. Any thoughts on what this can be? My initial thoughts are bearings, trans, differentials, u-joints. Seems like too soon for any of those parts to fail. Thanks!
Old Sep 12, 2022 | 8:44 PM
Kenrbass's Avatar
If you put it in neutral and it goes away, does it still exist? If it goes quickly away letting off the gas, it is sometimes rear end or drivetrain. If you swerve left and right you change weight on each side. Sometimes as you do that the sound gets louder as you put the weight on one side with the swerve. That usually is a wheel bearing
Old Sep 13, 2022 | 7:38 AM
repairman54's Avatar
How many miles on it? Front hubs are a common issue on every modern vehicle. My '11 front hubs didn't even make 100k miles. And a couple replacements didn't either.
Old Sep 14, 2022 | 6:29 AM
Jason PM's Avatar
No change when I put the truck in neutral. It does seem like the humming is slightly louder when going around a left hand curve. I have an appointment to have it checked by the dealer on Friday. Will say what they say. Thanks!
Old Sep 14, 2022 | 6:30 AM
Jason PM's Avatar
50k miles
Old Sep 14, 2022 | 4:32 PM
Kenrbass's Avatar
If it is louder on a left curve, the issue is on the right side
Old Sep 16, 2022 | 8:47 PM
Jason PM's Avatar
It was the passenger side front bearing. Thanks!
Big SUV
Nov 18, 2021 12:33 PM
Scottdecker980
Oct 25, 2021 7:44 AM
h3xc0re
Feb 27, 2021 7:39 AM
One1014
May 17, 2018 7:45 AM
