2020 Suburban Air Ride Problem
I have a 2020 Suburban and a couple months ago the air ride compressor started running frequently.
From reading threads it sounds like I have a leak, either in the lines or the struts. And, it seems that a good idea would be to swap out the air ride struts/shocks with non-air ride units.
Can I simply replace the front and rear struts/shocks, and install a 3.9 ohm/25 watt resistor at each corner and that's it?
Is it more complicated than this?
Can anyone recommend which struts/shocks to get?
Thank you!
Thank you!
