2021 Tahoe Premier - Constantly needing to replace battery in FOB
Old January 4th, 2024 | 10:21 AM
GHeeb's Avatar
Default 2021 Tahoe Premier - Constantly needing to replace battery in FOB
New here and did try to search if this topic was covered already. Apologies if it had, really hoping it has.
Upon powering off the Tahoe, it reminds me to replace the battery in the fob. I’ve had the Tahoe for a year and have replaced the battery three times. Most recently yesterday and did not see the message after replacing. Not even 24 hours later and received the message again to replace the battery in the Fob.
Is having a faulty FOB unrealistic? Should I get a replacement FOB or anyone else experience similar and had something work for you?
Old January 4th, 2024 | 10:43 AM
Rednucleus's Avatar
Welcome to Chevy - if still under warranty I would pester your dealer 1st
mountainmanjoe (January 4th, 2024)
Old February 21st, 2024 | 9:09 PM
jSands's Avatar
Default Need the same help? 2032 Z71 Tahoe Replace Ke
Old February 21st, 2024 | 9:11 PM
jSands's Avatar
Default 2032 Z71 Tahoe Replace battery in key
I have had mine to the dealership 6 times and this keeps happening?? Any help out there?? It’s back at the dealership now, they called and said well now it’s out of warranty and I will need to pay for diagnostic testing?? I have an extended warranty, but I don’t think they should use i
thr extended since they have never fixed it to begin with. Lost!!!
Thanks,
Old February 21st, 2024 | 10:45 PM
Welcome to the forum. Have you checked the voltage of the batteries in the fob that you're replacing? If they are still at nominal voltage that's printed on the batteries then the message is in error. You should check the main battery voltage because the electronics can go haywire when it gets below 12 volts. A fully charged battery should be around 12.7 volts.
Starting with the 2007 model, Chevrolet started using the computer to control the alternator output. And they would just charge when absolutely necessary to keep the battery up. This was ostensibly to improve gas mileage. 🤔
Old February 21st, 2024 | 10:55 PM
jSands's Avatar
[QUOTE=73shark;500528]Welcome to the forum. Have you checked the voltage of the batteries in the fob that you're replacing? If they are still at nominal voltage that's printed on the batteries then the message is in error. You should check the main battery voltage because the electronics can go haywire when it gets below 12 volts. A fully charged battery should be around 12.7 volts.
yes, they have replaced the batteries, voltage was alway normal. Reprogrammed x2, said that when they did testing they showed interference at a near by gas station, replaced a part that received communication from the key fobs( sorry I don’t remember the name of this part) I would have assumed checked battery to vehicle. I will ask this question about the vehicle battery when they call me back.
Old February 21st, 2024 | 11:24 PM
So you're saying that the batteries removed from the key fob when it was indicated that they were in need of replacement still checked good?
Old February 22nd, 2024 | 7:49 AM
jSands's Avatar
[QUOTE=73shark;500532]So you're saying that the batteries removed from the key fob when it was indicated that they were in need of replacement still checked good?
Yes. They kept asking me where the vehicle is parked? Saying there is some kind of interference they defected when they checked it at a near by gas station? I told them in my garage with basic att Wi-Fi.
Mikd
October 11th, 2022 5:17 PM
Ogden434
January 11th, 2016 3:20 PM
Eagles
February 11th, 2015 9:45 PM
89scottsdale
September 23rd, 2014 1:47 PM
societydweller
HHR
February 16th, 2009 4:23 PM
