3 sensors for automatic a/c control... what are they and where?
Old Sep 15, 2020 | 10:23 AM
  #21
georgesblazah's Avatar
Originally Posted by shawnvw
AUTOMATIC SYSTEM
HVAC Control Module C1
Connector Part Information
  • OEM: 15491305
  • Service: 15126709
  • Description: 20-Way F USCAR 0.64 Series (BN)
    Terminal Part Information
  • Terminal/Tray: SAITS-A03T-M064/14
  • Core/Insulation Crimp: P/P
  • Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU)
  • HVAC Control Module C1
    Pin
    Wire Color
    Circuit No.
    Function
    WH/BK
    5515
    Inside Air Temperature Sensor Assembly Control
    2-3
    Not Used
    D-GN
    734
    Inside Air Temperature Sensor Signal
    GY
    1548
    Passenger Sunload Sensor Signal
    BN
    404
    Upper Air Temperature Sensor Signal (C69)
    L-GN
    405
    Lower Air Temperature Sensor Signal (C69)
    8-13
    Not Used
    14
    D-GN
    5518
    Auxiliary Inside Air Temperature Sensor Signal (C69)
    15
    L-BU/BK
    590
    Driver Sunload Sensor Signal
    16
    TN
    516
    Upper Left Air Temperature Sensor Signal
    17
    TN
    517
    Upper Right Air Temperature Sensor Signal
    18
    PK
    2145
    Air Temperature Switch Signal - Right (C69)
    19
    GY
    2599
    Auxiliary Mode Door Control (C69)
    20
    Not Used
    HVAC Control Module C2
  • OEM: 15491285
  • Service: 15136073
  • Description: 16-Way F Kaizen 0.64 (BK)
    [ul][/ul]HVAC Control Module C2
    Pin
    Wire Color
    Circuit No.
    Function
    RD/WH
    3340
    Battery Positive Voltage
    2-3
    Not Used
    L-GN/BK
    735
    Ambient Air Temperature Sensor Signal
    D-GN
    5060
    Low Speed GMLAN Serial Data
    D-BU
    204
    A/C Low Pressure Sensor Signal
    Not Used
    BK/WH
    1851
    Ground
    OG
    300
    Ignition 3 Voltage
    10
    WH
    193
    Rear Defog Relay Control
    11-14
    Not Used
    15
    BK
    1050
    Ground
    16
    D-GN
    6101
    Low Reference
    HVAC Control Module C3
  • OEM: 15491304
  • Service: 15126710
  • Description: 20-Way F USCAR 0.64 Series (GY)
    [ul][/ul]Terminal Part Information
    [ul][/ul]HVAC Control Module C3
    Pin
    Wire Color
    Circuit No.
    Function
    TN
    518
    Lower Left Air Temperature Sensor Signal
    YE/BK
    713
    Defrost/Heater Mode Valve Position Sensor Signal
    PU
    1838
    Recirculation Door Position Signal
    GY/BK
    754
    Blower Motor Speed Control
    5-9
    Not Used
    10
    GY
    598
    5-Volt Reference
    11
    TN
    520
    Lower Right Air Temperature Sensor Signal
    12
    L-BU
    733
    Air Temperature Door Position Signal
    13
    D-BU
    1646
    Auxiliary Air Temperature Door Position Signal (C69)
    14
    Not Used
    15
    TN
    2273
    Mode Door Control
    16
    D-BU
    1199
    Air Temperature Door Control
    17
    D-GN
    1614
    Recirculation Door Control
    18
    WH/BK
    1236
    Auxiliary Air Temperature Door Control (C69)
    19
    Not Used
    20
    YE
    1791
    Low Reference
    HVAC Control Module C4 (C69)
  • OEM: 15483874
  • Service: 21997401
  • Description: 16-Way F Kaizen 0.64 Series (GN)
    [ul][/ul]HVAC Control Module C4 (C69)
    Pin
    Wire Color
    Circuit No.
    Function
    Not Used
    GY
    596
    5-Volt Reference
    OG
    2215
    GY
    2614
    Not Used
    GY/BK
    1798
    Low Reference
    BN
    5516
    8-9
    Not Used
    10
    D-GN
    2211
    Auxiliary Blower Motor Speed Control
    11-16
    Not Used
    Any way to get these diagrams back? I think I have a malfunctioning temp sensor on the passenger side thats throwing off my climate control. Sorry for the old post bump lol
    Old Sep 20, 2020 | 5:51 PM
      #22
    Breadedturnip's Avatar
    The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
    Ambient Air Temperature Sensor [align=left]•
    Inside Air Temperature Sensor Assembly [/align][align=left]•
    Upper Left Air Temperature Sensor [/align][align=left]•
    Upper Right Air Temperature Sensor [/align][align=left]•
    Lower Left Air Temperature Sensor [/align][align=left]•
    Lower Right Air Temperature Sensor [/align][align=left]•
    Upper Air Temperature Sensor - Auxiliary [/align][align=left]•
    Lower Air Temperature Sensor - Auxiliary [/align]
    A signal and low reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40 to +101°C (-40 to +215°F). The sensor signal varies between 0-5volts.
    The input of the duct air temperature sensors are different from the ambient and inside air temperature sensors. The HVAC control module converts the signal to a range between 0-255counts. As the air temperature increases the count value will decrease. If the HVAC control module or auxiliary HVAC control module detects a malfunctioning sensor, then the control module software will use a defaulted air temperature value. The default value for the ambient and inside air temperature sensors will be displayed on the scan tool. The default value for the duct air temperature sensors will not be displayed on the scan tool. The scan tool parameter for the duct air temperature sensors are the actual state of the signal circuit. The default action ensures that the HVAC system can adjust the inside air temperature near the desired temperature until the condition is corrected.
    The ambient air temperature sensor mounts underhood and can be affected by city traffic, by idling, and by restarting a hot engine. Therefore, the HVAC control module filters the value of the ambient air temperature sensor for temperature display. The ambient air temperature value is updated under the following conditions:
    Condition
    Display
    At start up with the engine off less than 2hours
    Displays last stored temperature
    At start up with the engine off more than 2hours
    Displays real-time temperature
    Engine coolant temperature is less than 28°C (50°F) above the ambient air temperature
    Vehicle speed above 32km/h (20mph) for a minimum of 80seconds
    Vehicle speed above 72km/h (45mph)
    Sensor reading is less than the last displayed value
    The scan tool has the ability to update the displayed ambient air temperature. To update the ambient air temperature display on the HVAC control module, perform the following procedure: Turn ON the ignition. Simultaneously press the A/C and Recirc switches for 5 seconds
    Sunload Sensor Assembly
    The sunload sensor is a 2-wire photo diode. The vehicle uses left and right sunload sensors. The 2sensors are integrated into the sunload sensor assembly. Low reference and signal circuits enable the sensor to operate. As the light shining upon the sensor gets brighter, the sensor resistance increases. The sensor signal decreases as the resistance increases. The sensor operates within an intensity range between completely dark and bright. The sensor signal varies between 0-5volts. The HVAC control module converts the signal to a range between 0-255counts. The sunload sensor provides the HVAC control module a measurement of the amount of light shining on the vehicle. Bright, or high intensity, light causes the vehicles inside temperature to increase. The HVAC system compensates for the increased temperature by diverting additional cool air into the vehicle. If the HVAC control module detects a malfunctioning sensor, then the control module software will use a defaulted sunload value. This value will not be displayed on the scan tool. The default action ensures that the HVAC system can adjust the inside air temperature near the desired temperature until the condition is fixed. The scan tool parameter for the sunload sensor is the actual state of the signal circuit.
    Would you happen to know the location of the upper and lower left and right temperature sensors it what would cause all of them to read -51 and my evaporator air temp desired to read-9?
    Old Jul 11, 2021 | 6:47 PM
      #23
    intableass's Avatar
    I have 2008 chevy trailblazer with digital climate control and ac hasn't worked in while and everytime i try to. Change setting it still won't come on 'but the other day it just came on at random can you or anyone tell me what the prob may be
    GaryMD
    Oct 23, 2018 12:34 AM
    gonmoises
    Sep 28, 2011 9:19 AM
    fulltimer1
    Sep 26, 2011 12:08 PM
    joecoolnow
    Oct 29, 2007 10:37 AM
    myCHEVYkicksass
    Apr 3, 2007 2:19 PM
