4L60E no 4th gear
Old Nov 14, 2017 | 4:57 PM
hotsplice1970's Avatar
Newly Registered
Default 4L60E no 4th gear
I have a 4L60E transmission in a 98 Z71 pick up. The problem is that when I am riding down the road, it shifts 1st, 2nd, and 3rd, then the engine revs and wont shift into 4th 9overdrive)... is there a simple fix for this or do I need to rebuild the entire transmission?
Thank you!!!
Old Nov 14, 2017 | 9:02 PM
oilcanhenry's Avatar
Thank you!!!
Probably one of these:
1. Band is worn.
2. Servo problem - a worn seal or cracked 4th servo piston.
3. Bad Valve body
How many miles does the vehicle have on it?
