4wd bulbs
Old Sep 1, 2014 | 10:25 AM
04Burban's Avatar
Default 4wd bulbs
Does anyone know what type of bulb is needed for the transfer case buttons? Or better yet is there a list anywhere of bulbs for all the interior? I have a couple more out just can't remember exactly which ones. I thought about just replacing the entire switch unit but if I can get bulbs for cheap I don't mind taking it apart. Thanks
Old Sep 4, 2014 | 12:37 PM
TahoeLTGuy01's Avatar
Default bulbs
I don't think there is a way replace, just have to buy the whole switch. I have replaced the 4WD on my old 96 Tahoe. My current 2001 go out once in a while so I may need to replace my switch soon. Check ebay.
Old Sep 8, 2014 | 8:05 PM
04Burban's Avatar
I bought a Dorman replacement and wasn't happy with it. The lettering looks cheaper than than the factory unit and the lighting is a too green compared to stock. Also could see the orange led's light up around the button itself and just didn't look clean IMO. Now I even screwed up my chance on returning it because I tried to just swap bulbs and re use the factory unit, but I damaged it a little in the process. So I put the stock box back in and just dealing with the lights out until I find a way to replace the bulbs. There has to be a method, no light bulb is just irreplaceable. I just need to figure what type of bulb they are and get to soldering most likely.
Old Sep 8, 2014 | 8:33 PM
therewolf's Avatar
Hey, 04Burban, Welcome to the Chevrolet Forums.
Actually, lately they have been soldering some of the
new neon bulbs in line to circuits so they light when activated.
But I can't speak to your specific shift unit.
Old Sep 11, 2014 | 4:09 PM
04Burban's Avatar
Well at least it is being done somehow... I can do it once I see the idea of how its done, I just don't know enough to go in and start unsoldering and resoldering things.
Old Oct 13, 2014 | 5:20 PM
Default switch
i would just go to the dealer and buy the oem gm factory unit. I have done this myself in the past and was happy. Seems more time and effort than its worth to mess with indivitual bulbs.
Old Oct 14, 2014 | 8:52 AM
SabrToothSqrl's Avatar
Default Type? Pics?
I'm going to assume you have a 4x4 2004 Suburban from your handle, but we may be better able to assist if you can confirm that.
thanks
Old Oct 15, 2014 | 9:00 AM
04Burban's Avatar
Yes it is a 2004 2500 with the auto 4x4 option. I haven't had much time to deal with it lately or any luck finding a bulb type.
vpbho
Nov 1, 2010 10:08 AM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
wwotr
Jun 4, 2007 9:15 PM
