4WD engaging Problem
![Angry](https://chevroletforum.com/forum/images/icons/icon8.gif)
I have a 1996 K2500 4WD Suburban wit a 454 cid. When I attempt to engage the 4Hi the t-case fuse #2 blows been through 3 fuses so far any ideas on how to fix this?
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
I would check for a short but it could be a bad transfer case. Try unplugging the connector and see of it still blows when you try to change modes. If so check to see if the wires have a connection to ground. Im sure that at least one is ground so you would have to get a schematic to see which is what. I have never had issues with mine so I have never had it appart.
Nathan
Nathan
Nathan
Nathan
99.9 percent sure it is gonna be your 4wd actuator on the front differential switch that out then try a new fuse. You'll have to figure out which style it is motor heated element, just go by the number of wires in the harness going to the actuator and how many pins the connector has.
pacaguy
January 18th, 2022 1:00 PM
UncleDudley
April 2nd, 2008 4:02 PM
holyspatulaboy
February 20th, 2008 5:26 PM
