4WD Question
I have a 2011 Suburban. I've had it for almost a year, it has about 140k miles on it.
I had some issues with it a while back and had to have the front left wheel hub and the sway bar linkages replaced.
I put it in 4WD last weekend, and found that it has a severe impact on the turning radius. I can't turn nearly as tightly. When I do, it just feels and sounds like I am crushing something.
Is something wrong? Or is this normal? It's perfectly fine if I don't turn tightly. I really only feel this when I'm parking.
They were a little icy. We got a few inches of snow earlier in the day, and people were driving on the parking lot all day.
But it's not like it was a huge snow. I think we got 2-3 inches total.
I would have the transfer case fluid changed if you haven’t already. Double check your owners manual to see you have the correct fluid in it. If you don’t have the owners manual type in your VIN into the VIN checker in the tools section. If you have an Autotrack 4WD system you need Autotrack II fluid. Never believe the previous owner on questions regarding the maintenance they claim they have done. Also, same with the lube in the front axle. Have it changed if you haven’t done so since you bought it. Just my two bits.
SD
SD
My front tires are struggling to stay above 23 psi right now. I fill them almost daily. So I am taking it in tonight to a garage to have them figure out why they won't hold air. (But they never fall below 21 psi.)
Thanks for that!! I feel better now. Hopefully I have 1 problem showing itself in 2 ways!!
