4x4 not engaging
Old August 25th, 2006 | 8:12 PM
timdogg1313's Avatar
Default 4x4 not engaging
my 4x4 won't engage when i press the button for 4hi or 4lo. The light will blink and it sounds like the transfer case is engaging(almost a clanking sound), but it won't lock in. please respond with ideas or thoughts.
Please let me know if i should post this in a different area!
thanks in advance,
Old September 9th, 2006 | 8:01 PM
ZX1100F1's Avatar
Default RE: 4x4 not engaging
Tim,
It sounds as thought the front axle central locking actuator is bad.
Easy to replace.
GM also recommends that you replace the lube in the front differential with 75W90 Synthetic Gear lube on the older Tahoe's, this will enable the front propeller shaft to rotate easier and allow the vehicle to lock into 4-wheel drive quicker which will reduce the strain on the actuator and also synthetic lubricant reduces the operating temperature as is a better quality product.
Natty68
February 27th, 2015 7:54 PM
doubld
April 29th, 2014 7:30 AM
stevesobel24
December 2nd, 2011 2:10 PM
BYUFanatic
August 2nd, 2008 2:30 PM
holyspatulaboy
February 20th, 2008 6:26 PM
Quick Reply: 4x4 not engaging
