5.3L intake
Old Feb 12, 2014 | 11:54 AM
willep74's Avatar
Default 5.3L intake
hello,
does anyone know if the plastic intake manifolds on the 5.3L FFV engine can be machined? a recent smoke test revealed an intake leak and I was thinking since I have to take it apart anyway that I would get the intake checked to see if it warped.
If it did warp am I just stuck buying a new one? this is on a 2003 1500 Suburban with 170k on the clock.
thanks for any help!
Old Feb 21, 2014 | 4:25 PM
DeeK01's Avatar
New User
Awaiting E-mail Confirmation
To answer your original question I’m going to say no. these intakes have groves molded into them that hold the rubber seal/gasket, and since it does use this type seal it is very unusual that a warping issue would be the cause of leak.
The great thing about these LS motors is that the seals are reusable & don’t require rtv or sealant. If I were you I’d just take it off & see is there is any spot that looks unusual, it bolts right on & off. Just keep track of everything and make sure everything is clean & clear for dirt & sand. Maybe just a new seal will do the trick.
dry_kill
Apr 17, 2006 6:21 PM
heavychevyjj
Jun 17, 2005 3:48 PM
