5.7 Vortec lost a cylinder
Old Aug 22, 2022 | 4:39 PM
MrAdam's Avatar
Default 5.7 Vortec lost a cylinder
Hi guys. My 98 Suburban (4x4 5.7 Vortec) died on the highway yesterday. Towed it home and after pulling the plugs cylinder 3 plug looked sooty. The truck will only start with that plug removed, and it actually runs well on 7 cylinders. But I f that plug is reinstalled it won’t hardly crank a full revolution because of what sounds like a binding problem.
I pulled the valve cover and I don’t see anything noticeable wrong with those valve springs or rockers, even when cranking the engine. Anyone have an idea on how to proceed? Stuck shut valve, or a bent pushrod maybe?
thanks for any and all help! I’ve had this truck for 7 years and still love the thing.
Old Aug 22, 2022 | 9:58 PM
oilcanhenry's Avatar
A motor is just a pump of sorts, so it has to vent the exhaust flow. No chance anything fell into the combustion chamber? If something is plugging up the #3 exhaust, that would be a possibility. Frankly, I think something is amiss with your # 3 piston and/or the connecting rod, but a bent push rod or a shot hydraulic lifter could be it.
Old Aug 22, 2022 | 11:41 PM
Welcome to the forum. Does the #3 exhaust valve operate when cranking the engine?
Old Aug 23, 2022 | 10:02 AM
repairman54's Avatar
Compression test with all the plugs out to see the overall condition. All should be within 10% of each other as a first step before any teardown.
SeanOD
1988 - 1998 (GMT400)
Oct 7, 2018 9:54 PM
75K10
Sep 10, 2014 6:25 PM
tay2168
Jan 18, 2012 6:31 PM
Eric Kropp
May 28, 2009 9:51 PM
