92' suburban 4x4, Where do these go? And what goes here?
Old Oct 17, 2017 | 9:02 PM
Aoist's Avatar
Default 92' suburban 4x4, Where do these go? And what goes here?
Long story short, I removed a lot of parts off the engine and also removed the front differential, thinking that I was going to replace the crank. Well that was 6 months ago. And Recently, after putting everything together , I have a couple of 16", 1/2" diameter braces that I can't remember where it goes. The opposing mounting holes on one is twisted at 90 degrees and the other one at about 45 degrees. I'm pretty sure it came off from under the vehicle( forward of torque converter inspection cover) but not am certain. Anybody know? As you can see in the picture, I save the bolt/nut and is on one end the braces, which means that more than likely the other end of the braces goes on to a bolt that is currently holding something else together.
Another question is, what goes on the 2 mounting holes on the bottom of the torque converter inspection cover, I know some thing goes on there because I have the bolts for them. Or could the braces go on there? I looked but I couldn't find the holes for other ends of the braces. I like to drive the vehicle but I'm a bit leery now because of this. Thanks for your help.
Pictures: https://i.imgur.com/4mKAaws.jpg https://i.imgur.com/Mfw7hdX.jpg
Old Oct 17, 2017 | 11:23 PM
Rednucleus's Avatar
Those are the braces from the front of the transmission to the back of the motor
Old Oct 18, 2017 | 8:06 AM
Aoist's Avatar
Hey Rednucleus I lived in Washington for 20 years, In fact I brought this car from there a couple of years ago. Thanks bud,
Old Oct 18, 2017 | 10:00 AM
Aoist's Avatar
Solved, it goes to near the motor mounts on either side but it was very hard to see the mounting brackets because they are vertical and the holes are not visible from under the car.
Thanks Guys
