'93 c1500 stuttering/hesitation at take off
Old Dec 23, 2011 | 1:31 PM
Rupesy's Avatar
Default '93 c1500 stuttering/hesitation at take off
Just started stuttering when I just start to pull out. Idles fine. Runs fine a high speeds. Accelerates fine. Whenever I push the pedal just slightly, it stutters/hesitates and then takes off. Plugs, cap, coil and wires, air filter are very recent. Any recommendations on what to check?
Old Dec 23, 2011 | 3:08 PM
hicksvilleshick's Avatar
dirty throttle body???
:chug:
Old Dec 24, 2011 | 10:44 AM
Rupesy's Avatar
I bought some cleaner so I will give that a try. The weird part is that it does not do this when I first start it. I can drive it for a few minutes without the issue. I know the OBC does not kick in until the temp gets to a certain level. Seems like it starts to do that once it gets to temp.
Old Feb 24, 2013 | 1:19 PM
Rupesy's Avatar
Just posting a follow up. I saw a incident where a guy replaced his injectors and the issue went away. Since it has 135k, I decided it would be worth it anyway. I found a new set on ebay for $90. I replaced those and the throttle position sensor and she is now running like a champ again! My feeling is that it was the injectors, but didn't have time to change out one at a time.
Old Apr 28, 2013 | 8:48 PM
Dusty1's Avatar
I am also having similar issues I replaced spider Injector, fuel pressure regulator,fuel pump,fuel filter, spark plugs and wires . With all this when I run my 96 c1500 for a while the problem goes away but once I hit about 60 it does it again and then it's fine after that. At first it was even idling rough so I tweaked the idle screw now it idles fine but still hesitates off the line. I cleaned the throttle body completely. I'm thinking it may be my throttle position sensor but I do not want to spend money on something I don't need any ideas ?
skycranemech
Oct 3, 2011 7:13 PM
igottagal@yahoo.com
Jul 13, 2011 11:20 PM
tom5170
Mar 16, 2010 9:41 PM
dash4g
May 13, 2009 2:20 AM
