94 Suburban, No start issue
Old Sep 9, 2014 | 6:08 PM
mamameg24's Avatar
Default 94 Suburban, No start issue
I have 94 Suburban K1500 5.7L
2 weeks ago, on a Monday, had mechanic (husband not mechanical) replace cap, rotor, plugs and wires, as engine REALLY needed it.
Ran fine, better than in long time, the next day, Tuesday.
Wednesday morning, son started up to move, it died as he was backing up. Would not restart, crank and crank and crank, no turning over. Tried jumping it, nothing (could hear fuel pump turn on during this, before beginning to crank). Then finally battery started dying, no crank at all, but still had headlights, dash lights, etc. (battery only 6 months old). Thought maybe alternator, took for testing, not the problem.
Husband came home, noticed a wire hanging that was previously connected to battery post. Put new wire connector on. Cranked for about 5 seconds, then nothing. But still had headlights, dash lights etc. Checked all fuses, all good.
Bench tested, and took to Napa, the starter. Starter good. It is getting power to it.
Husband wants to send to back to mechanic, but I want to exhaust everything we can do at home first. How do we test the coil? I've read that bad misfire (as it was doing before cap & rotor replacement) can fry the Ignition Control Module.
Any suggestions?
Old Sep 9, 2014 | 9:32 PM
Rednucleus's Avatar
ICM in the distributor (if same as my 93) can cause no start and easy to replace. My Sub has 360k on it and is on it's 3rd module.
Old Sep 9, 2014 | 11:32 PM
I would also do fuel pressure check. Just because you can hear the fuel pump running, doesn't mean it is producing the correct pressure.
Old Sep 10, 2014 | 10:38 AM
mamameg24's Avatar
Would no crank at all be caused by low fuel pressure?
Old Sep 11, 2014 | 6:26 PM
Rednucleus's Avatar
Are you saying the starter is not turning the motor over?
CHEVYCRZY007
Jan 15, 2013 8:50 AM
timmy7728
Oct 20, 2012 7:31 PM
Stimpy911
Oct 12, 2011 2:40 AM
bracca
Jul 12, 2009 6:14 PM
Suburbman
Sep 30, 2007 3:45 PM
