94 tahoe wont turn over! help please
Hey, im new here. I have a 94 full sized chevy. has 120 miles on it. good truck recently while driving the truck would randomly shut off or stall. i would turn the key while in nuteral and it would start up again. One day it didnt start back up. The key would not come out of the tumbler. i got the key out eventualy. after fighting. so now i checked my fuses, all good. the entire interiour turns on. radio and fans. but when i go to start it it wont click or turn over or anything.... battery is good. i replaced the starter because i have had a problem with it in the past. im getting power to the starter. but it wount turn over... i have been thiunking maby its a netural safty switch? or the tumbler it self? what about a inginition switch. im clueless now... anyone help me out please.
RE: 94 tahoe wont turn over! help please
When you say you're getting power to the starter, I assume you mean 12V to the starter motor. Have you checked to see if you are getting 12V to the solenoid when you twist the key to the "Start" position?
i replaced the starter and the starter selinoid. there is voltage going to both. but the truck wount turn over and the selinoid doesnt make a noise.
If you have 12V to the solenoid and it's wired correctly and it doesn't kick in the starter, then my guess is that you have a bad solenoid or bad ground.
im getting power and ground to the selinoid. its a brand new selinoidand starter. so i doubt that. as for the ground what do you mean? the starter/selinoid isnt ground? because it is. i got shocked to hell when i touched it with the wrench.
Hi
First of all have you checked engine is spining freely with wrench/socket?If you suspect park/neutral safety switch,just disconect cable,make it neutral or park manually,then try with a small jumper wire to jump the pin of starter relay to if see if turn over.
thisnthat
November 20th, 2012 11:36 AM
Chevrolet Forum News
September 25th, 2012 8:48 AM
audrey
April 3rd, 2008 10:30 PM
