95 tahoe idle up and down
Old Mar 12, 2010 | 6:31 PM
chuck5001's Avatar
Default 95 tahoe idle up and down
hi. I have a 1995 tahoe 106,000 miles on it. it recently started acting up i. It runs fine when its cold outside, but when it warms up it runs rough stalls and idles up and down about 800 rpms. almost to stall and then back up to normal. I replaced the throttle control sensor, but the problem has persisted any help would be greatly appreciated. thanks, chuck
Old Mar 12, 2010 | 6:33 PM
maxxman04's Avatar
is it only at idle? could be that the idle air control valve and maybe the egr need cleaning.
Old Mar 12, 2010 | 6:34 PM
maxxman04's Avatar
oh yeah, welcome to our forums!!
Old Mar 12, 2010 | 6:35 PM
chuck5001's Avatar
it does it while at idle, but also on highway when you let off the gas. thanks, chuck
Old Mar 13, 2010 | 5:55 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Yep, sounds like the IAC is acting up.
Old Mar 16, 2010 | 7:06 PM
chuck5001's Avatar
changed out the iac, and map sensor. still no luck. go out in the morning when its cool out runs good. after work 55 degrees out starts the up and down idle. any ideas? thanks chuck
Old Mar 16, 2010 | 7:11 PM
maxxman04's Avatar
possibly egr. maybe timing. maybe
Old Mar 16, 2010 | 7:27 PM
chuck5001's Avatar
thanks maxxman. I am going to check the egr tomorrow. just not sure where it is located. thanks for all your help. chuck
Old Mar 16, 2010 | 8:17 PM
maxxman04's Avatar
is it throttle body injected, or a vortec?
Old Mar 17, 2010 | 4:06 AM
chuck5001's Avatar
it is throttle body
