96 K2500 Suburban Transfer Case
Old Aug 7, 2011 | 1:23 PM
Tilar's Avatar
Default 96 K2500 Suburban Transfer Case
Howdy all,
I have a problem with my transfer case. When I first bought the truck a few years ago, it had the snap ring broke on the rear tail shaft which was an easy fix. I noticed toward the end of this last winter that when I put it in 4wd, it has a popping noise coming from the transfer case. The 4 wheel works but when you put it under any load it pops.
What should I look for, and if I need to, what all is involved with taking out the transfer case? I've been an equipment mechanic my entire life and have rebuilt many car engines and automatic transmissions so I feel comfortable doing this, but i've never been in a transfer case other than to replace the snap ring mentioned above.
One other thing, When I put it in 4wd, it seems to take a good while to engage. The light blinks and seems to take about a minute before it stays on, sometimes a little less and then sometimes I need to go back to 2 wheel and then push 4 wheel again. Could both of these problems be related or do I maybe have a solenoid on the front differential that might need replaced?
This has the 7.4 if it makes any difference.
Thanks in advance for any suggestions.
Old Aug 13, 2011 | 1:58 PM
Tilar's Avatar
Nobody ever had this problem before?
bossman78
Dec 26, 2018 7:52 PM
tlarimer3187
Mar 20, 2015 9:21 PM
Curt
Jun 2, 2010 3:27 AM
jrsavoie
Feb 24, 2010 2:38 PM
rowekmr
Aug 7, 2009 12:18 AM
