96 Suburban, only 5v at Fuel Pump Relay??
Old Nov 13, 2007 | 8:05 AM
calponte's Avatar
Default 96 Suburban, only 5v at Fuel Pump Relay??
Hi.
Trying to trouble shoot a fuel pump problem with a 96 Suburban.
Fuel pump does not come on and no pressure on high-side line.
Relay functions when key is cycled but there is only ~5v coming to and going out of the relay.
Any ideas?
Thanks so much[/align]
Old Nov 13, 2007 | 8:31 AM
DAVID L. PAUL's Avatar
Default RE: 96 Suburban, only 5v at Fuel Pump Relay??
fuel pump bad
Old Nov 13, 2007 | 8:34 AM
calponte's Avatar
why?
Old Nov 13, 2007 | 9:01 AM
some vehicles don't require a full 12 volts for the fuel pump but to be sure locoate your inertia switch and un plug it and hook a 12 volt jumper wire to the one going to the fuel pump and see if it will run that way
Old Nov 13, 2007 | 9:12 AM
RonH's Avatar
If the fuel pump refuses to start, you may be able to get it going by hitting the bottom of the fuel tank with a rubber mallet or something similar. If it start when jarred this way, you will know for sure it's fuel pump going out.
Old Nov 13, 2007 | 10:13 AM
calponte's Avatar
Oh ok. Does anyone have a diagram or know which color is the postive feed to the pump?
And is there an inertia switch on these trucks? I thought there wasnt
mistersuburban
Jun 26, 2019 8:14 AM
BRB
Dec 28, 2012 8:34 PM
speeddemon
Jan 24, 2012 10:22 AM
hunter10220
May 18, 2011 8:37 PM
