96 tahoe non rear ac conversion
Old Jun 23, 2016 | 4:20 PM
96mdtahoe's Avatar
Default 96 tahoe non rear ac conversion
Hello everyone. Been searching this subject but can't find anything. I have a 1996 ls tahoe 4x4 with no rear ac. Is it possible to install a rear ac in it?
Old Jun 26, 2016 | 1:16 AM
justimagination's Avatar
First you would need a donor vehicle in order to have everything needed, such as Headliner and duct work, the rear Evaporator unit and hoses, a lot of wiring harness, and a lot of time. YES it's doable but not advisable. JMHO. good luck.
David g.
Old Jun 26, 2016 | 7:52 PM
yep, find a donor at the wrecker with the trans and driveline removed. have a look and see what you have to remove to get these lines in and out.
I have replaced rear lines on a new Durango and its a lot of work with a hoist let alone doing it on your back on the floor.
a larger displacement compressor is used on dual systems.
